I use the alert to notify when an item is deleted.
I open the form and delete an item and the alert shows. No problem.
I close the form and open it repeatedly - 10 times.
I delete an item, the application crashes withan argument exception "Parameter is not valid."
It's crashing on the line
Show(windowInfo);
I am just checking about the progress of this issue. Did you solve your issue accordingly to the information that I provided you? Did you test the sample I have sent to you?
Let me know if you need any further assistance.
Hello Abdul,
I have tested UltraDesctopAlert with 10.3.1000 and I wasn’t able to reproduce your issue (see the attached sample). The behavior which you are getting probably is caused of some other code in your application, could you please post some code snipped or give me more information about your real scenario. Also can you please let me know whish exact version are you using?
