165
Difference between DockableControlPane.Close and MdiTab.Close
This is most likely my misunderstanding of how Infragistics works, but I have the following scenario.
WinForm containing a dock manager and a mdi manager. This allows me to either dock or "fill" my panes in the form.
One pane contains a WebBrowserControl, inside which I am rendering a local web page (Bing maps.)
If the pane is a pane and docked anywhere, calling Close on it works without issue - the pane closes and can then be opened again with Show.
If the pane is a tab (Dockable false), calling Close on it is appearing to cause the WebBrowserControl to unload.
I have attached a sample of this behaviour, there is a debugger line in the javascript to show when the web page is being unloaded.
To use the sample
  • Build and run
  • Press Add Pin - Map is shown
  • Press Close - Map is hidden
  • Press Open - Map is shown
This all works fine to this point, the pin is still there and no errors are thrown
  • Right click the maps title bar, uncheck Dockable - Map fills available area
  • Press Close - Debugger step is thrown from the javascript file showing unload has been called
This is not the desired, nor expected behaviour - any advice on how to make this function as I was expecting would be much appreciated.
Thanks in advance!
(Edit) : I am away on annual leave until Nov 1st
WindowsFormsApplication5.zip
