935
AllowAddNew discovered from BindingSource property change
I am using an UltraGrid bound to a BindingSource with underlying custom class derived from BindingList<T> . The custom BindingList determines the AllowNew state from the filter criteria and other properties of the items in the list. The user may change these filter criteria and so change the AllowNew state. This triggers a ListChangeEventType.Reset.
The UltraGrid correctly reads the AllowNew variable in terms of enabling/disabling AddNew functionality and correctly processes or errors the users to attempt to add a new row.
But rather than reporting an error to the user, I would like to change the display accordingly with either AllowAddNew.FixedAddRowOnTop or AllowAddNew.No providing a visible indicator of whether the action is supported.
Is there any event or other means of being notified when the UltraGrid reacts to a ListChangeEvent or changes the AllowAddNew property. InitializeLayout only seems to fire for PropertyDescriptorChanged events not for the Reset event.
Any suggestions appreciated.
Wendy
