Hi.
I have a boolean column in a grid where i want to use a 'state' button Basically, if it is false, i am going to show one icon, and if true then i would show another Icon and have the button be disabled.
So far I set the style in the initgrid event:
c["isprinted"] = Style.Button
next, I set the image in cell appearence.
I imagine on the row init event I can set the right image.
The issue I am having is that it is showing a checkbox except when I mouse over ...then it shows the button. It is also displaying the 'false/true' text with the image..how can I make it image only?
Thanks.
Yes, that works out. It would be nice a State Button was in the custom editors.
Sorry Mike did not see your reply while I was posting, will give the CheckEditor a shot and verify back here.
I did set the columns style to Button.
c[
.Button;
It seems to me that it would be easier to do what you want here by using an UltraCheckEditor. You can set the Style of the control to Custom, then use the Appearance and CheckedAppearance to assign the two images you want.
Then you set the grid column's EditorControl to the UltraCheckEditor and the images will display in the cell based on the value.
I think what is happening is that the width of the column is insufficient to show both the checkbox and the state button, so when you mouse over the cell the button appears and takes up all available space so the checkbox isn't shown. I don't know what could be causing "true/false" to be shown because from what I remember those editor buttons don't display any text. In any case you can prevent the checkbox from appearing by either assigning an EditorWithText to the column's Editor property (thus preventing the CheckEditor from being used), or setting the column's Style property.
