225
execute some code when user click on column header
I need to execute some code when the user click on the column heander instead to sort them, It´s that posible?
Thanks in advace,
Alejandro Castrejon
  • 69832
    Verified Answer
    One way is to set SortIndicator to 'None' for the column, then handle the AfterSelectChange event for column selection. This event will also fire, however, when a column is programmatically selected, so if you need to unambiguously identify a click on the header, you can do this:
    void ultraGrid_MouseClick(object sender, MouseEventArgs e)
        UltraGrid control = sender as UltraGrid;
        UIElement controlElement = control.DisplayLayout.UIElement;
        UIElement elementAtPoint = controlElement != null ? controlElement.ElementFromPoint( e.Location ) : null;
        UltraGridColumn column = null;
        while ( elementAtPoint != null )
            HeaderUIElement headerElement = elementAtPoint as HeaderUIElement;
            column = headerElement != null ? headerElement.GetContext( typeof(UltraGridColumn) ) as UltraGridColumn : null;
            if ( column != null )
                break;
            elementAtPoint = elementAtPoint.Parent;
            //  Do stuff here
