This seems like a bug to me. The docs say the Task Project propery sets or gets the project associated with the task. Other code I have shows that the set property works, but this shows that the get does not
Create a new Windows Froms c# project, then put an UltraCalendarInfo on the form an use this code for your Form1.cs The last assert demonstrates the bug.
using
System;
System.Collections.Generic;
using System.ComponentModel;
System.Data;
System.Drawing;
System.Linq;
System.Text;
System.Windows.Forms;
Infragistics.Win.UltraWinSchedule;
Infragistics.Shared;
System.Diagnostics; // for Debug
namespace
WindowsFormsApplication4
Form
Form1()
InitializeComponent();
t.Project = p;
Debug.Assert(null != p);
Hello app3lam,
You could assign a project to a task using an approach like the following:
Project p = this.ultraCalendarInfo1.Projects.Add("FirstProject", DateTime.Today); p.Key = "s"; Task t = ultraCalendarInfo1.Tasks.Add(DateTime.Now, TimeSpan.FromDays(2), "1", p.Key); t.Project = p;
Please do not hesitate to contact us if you need any additional assistance.
Not sure why the code looked like that in the post, anyway, the form1.cs is attached in the file form1.zip
