Good morning,
have a toolbarmanager object on my form.
Has two buttons in a group. When I click on one I want to be able to call the other buttons click event within code.
I have:
Dim objBtn As Infragistics.Win.UltraWinToolbars.ButtonToolobjBtn = uwTBMgr.Ribbon.Tabs("Home").Groups("Search Orders").Tools("Search")Dim objE As Infragistics.Win.UltraWinToolbars.ToolClickEventArgsuwTBMgr_ToolClick(objBtn, objE)
How do I setup the ToolClickEventArgs object for the 2nd parameter?
thanks
Deasun
It is not recommended to do what you are trying to do.
Instead you should create a new sub (or function) with the code of the second toolbar button's event handler.The new sub is now available to be called from both toolbar buttons' event handlers.
As a good practice, the event handlers should be called only when the event is raised. The common code should be in it's on sub or function.
Hope this helps,
Emanuel
Hello tirnaog,
I prepared a sample for your scenario. Please review it and see if it fits your requirements.
Please do not hesitate to ask if something comes up, I will be glad to help.
Anybody ? :)
