1825
column hiding ?
Good morning,
Is there a way to put a btn on each column that when pressed would hide that column?
Somewhat like the Filter and Summary btns on each column that you can have.
Deasun
Parents
  • 469350
    Hi Deasun,
    There's no built-in way to add a button to a grid column header. You could do this with a CreationFilter, though.
    Another option would be to use the ColumnChooser. This allows the user to hide/show columns in the grid. The easiest way to enable it is like so:
            private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
                e.Layout.Override.RowSelectors = DefaultableBoolean.True;
                e.Layout.Override.RowSelectorHeaderStyle = RowSelectorHeaderStyle.ColumnChooserButton;
Reply Children
No Data
