When navigating in a long UltraWin grid and one expands to the second level, by then ticking a check box the scroll bar jumps to the very top as if performing a reset. How can this be prevented ?
I have created a support ticket with number: CAS-51912-NQF4N3, just to check if you still need a help.
Stefaniya
In combination with one of your methods we have found the root cause of the problem.
Please consider this case closed, it's just that this problem has lingered on for a quite a while.
Thx
Thanks for interim reply.
We have a dataset and a corresponding grid with 2-3 levels.
All tables have a column of Type boolean which are represented by checkboxes, and it is when a table exceeds the height of the screen and one ticks a checkbox that the scroll jumps upward, sometimes to the top sometimes halfway.
If our code is responsible are there certain properties / methods that may impact this.
Much obliged in advance.
What checkbox are you referring to?
Obviously, this is not the normal behavior of the grid to scroll when you check a checkbox, so my guess is that something in your code is causing this. Perhaps you are causing your data source to send a Reset notification or you are setting the DataSource on the grid.
