545
Optional (boolean) attribute from xml always true in Wingrid
I've a xml file with an element that contains an optional attribute (it's only available when it's true).
In my xsd scheme i use:
     <xs:attribute name="hit" type="xs:boolean" use="optional" default="false" />
I load the xml into a DataSet and set the winGrid datasource to that DataSet.
     this.newDataSet.ReadXml(xmlFileName, XmlReadMode.Auto);
When the xml file is loaded, the cell 'hit' in my Grid is always true. (checkbox checked).
Is there a property for the column 'hit' is need to change ?
I've tried a lot of things, but the cell 'hit' in my Grid remains true.
