250
Lock Column Width
I am using Ultragrid 10.1.20101.1007
I have my grid anchored to a form and when the form resizes i want the columns in the grid to resize also. I set the AutoFitStyle = ResizeAllColumns and it works as expected. I have  two columns that I want to prevent resizing so as per other posts in this forum I set the max and min widths to the same value.
However, this is not preventing the column from resizing.
The only thing I can think of that might be causing the problem is that my rows have columns in two levels. I tried LockedWidth = True but that only prevent the user from resizing but when the grid resizes the column does also.
Any Ideas?
TIA,
Kim
