I added a new group and three columns under it. When I run the application it showed the group and the columns fine. After I hid the group and tried to bring it back as a group, the field chooser shows the three columns separately. I cannot see the group under available fields. I must have missed some property when I created the group. Please help.
Let me know if you still need help or if you have any concerns.
Stefaniya
If you upload a small sample representing the described, I will be glad to research your question further. If you want you can send the sample and to the following support ticket that I created for you: CAS-51417-90T1T6.
I'm afraid you lost me. Where can't you see the group? In the grid or in the ColumnChooser?
Are you using RowLayouts with groups or the standard mode?
