1405
Grid Cell Images using DrawPhase
Currently I am adding images into cells (effectively replacing the UltraValidator) but I've run into some problems with the image format and so forth.
My question is: Which format does my image need to be in to be used in a cell? Dimensions? And what encoding should I use? ie) A .bmp may be saved in R5 G5 B5 or R8 G8 B8 etc
Here's a nice clear, concise image we are familiar with.
Here's an example of what my images appear as.. and yes I did add an alpha layer which doesn't seem to be working.
