Hi !!
I use the SelectedDateRange on the UltraMonthViewMulti and I've a little problem.
When I select a date range, for exemple : 10 july to 15 july.
umvmFrmXX.CalendarInfo.SelectedDateRanges[0] has 10 to 15 july selected.
But If I select after that the 12 july, the SelectedDateRanges[0] is not changing (10 to 15 july selected)
How could I set the UltraMonthViewMulti in this case to have only 12 july selected and not the precedent range ?
Thx, I found the solution, I was using a mousseCaptureEvent on the UltraMonthViewMulti, now I use a "MyUltraMonthViewMultiCalendarInfo_AfterSelectedDateRangeChange" event and things gone right.
I recently overloaded the SelectedDateRanges.Add method to include a 'clearExisting' parameter, which, when set to true, will clear the old range before applying the new one.
