Infragistics-Version: 10.1
Simply put three UltraTextEditors on a Form, give all of the three TextEditors a Default-Text (i.e. "TEXT 1", "TEXT 2" and "TEXT 3") manually set Focus on the first UltraTextEditor.
Now the Problem:
If you TAB through the 3 Fields, all of the Texts are automatically selected.
But if you change one the Fields, this Field is no longer automatically selected, it remembers the last Cursor Position.
How can I prevent this behavior??
Thx in advance.
Thank you very much for your anwer!
Handle the Enter event and call the SelectAll method. In order to do it for all text editors in your project, create a custom control that inherits UltraTextEditor, override the OnEnter method and add this call there. Drag your control instead of the original text editor.
