490
How to get ScrollBarInfo of UltraTree?
Could you please tell how to get ScrollBarInfo object of an UltraTree? Is there any way to get ScrollBarInfo object if I iterate through UIElements of UltraTree till I get its ScrollBarUIElement? I get the ScrollBarUIElement by doing the following:
 foreach (Infragistics.Win.UIElement uiElement in ultraTree1.UIElement.ChildElements)
                Infragistics.Win.UltraWinScrollBar.ScrollBarUIElement scrollBarUIElement = uiElement as Infragistics.Win.UltraWinScrollBar.ScrollBarUIElement;
                Infragistics.Win.UltraWinTree.VerticalScrollbarUIElement verticalScrollbarUIElement = (VerticalScrollbarUIElement)scrollBarUIElement;
                if (scrollBarUIElement != null)
                                //here i need a reference to ScrollBarInfo object (for tree's vertical scrollbar)                                                //what to do now?
I also tried to do the following in order to get ScrollBarInfo of ultratree, but it doesnot return me correct values of ScrollBarInfo:
AppearancesCollection appearancesCollection = new AppearancesCollection(null);
appearancesCollection.Add(ultraTree1.ScrollBarLook.AppearanceVertical);                Infragistics.Win.UltraWinScrollBar.ScrollBarInfo sbInfo = new  Infragistics.Win.UltraWinScrollBar.ScrollBarInfo(ultraTree1, Orientation.Vertical,  appearancesCollection);
Thanks in advance.
-Nazish Kanwal
  • 69832
    Yes, this recently came up with another product, so I added code to the GetContext method to recognize the ScrollBarInfo type. The fix was checked in on June 11 so I believe the latest service release contains this. You would then call the GetContext method off scrollBarElement, passing in typeof(ScrollBarInfo), and the returned object will be the ScrollBarInfo object the tree uses to manage its scrolling.
    Also note that the GetContext method was also revised recently to recognize typeof(System.Windows.Forms.Orientation), so you can now call GetDescendant off ultraTree1.UIElement, passing in typeof(ScrollBarUIElement) as the value of the 'type' parameter, and Orientation.Vertical as the value of the 'context' parameter, instead of iterating the ChildElements collection.
