I'm trying to emulate Visual Studio behavior in terms of floating pane sizing. The dock manager allows the windows to return to their default floating size when floated via the programmatic command or menu, however if the user drags a window (either from the title bar or tab if it is in a group) then it does not return to its previous size, and instead stays the width it was when docked in that area. Visual Studio automatically sizes it to its previous state.
Is there a place I can work around this? I've tried canceling the beforeDockChange and floating it myself, but I get asserts. I can also change the size once they have stopped the drag operation (in AfterDockChange) but this looks odd to the user since I'm using DragWindowStyle = LayeredWindowWithIndicators, the window stays same size while dragging and then changes once the mouse is released.
Patrick
This is a bug. I would recommend submitting it to the support group: http://es.infragistics.com/gethelp. Unfortunately, I don't believe there is a way to modify the pane size at the start of the drag operation.
