Hello.
I have a column chart. For instance the X axis represents the year monthes (Jan to Dec) and each month has a value associated with. I would like to be able to select several columns in my graph by using left mouse clik (and maybe CTRL button) in order to display a tooltip.
What I have already done:
Tooltips.Display = MouseClick
Tooltips.HighlightDataPoint=True.
Is there a way to select several columns easily ?
Thx
Eddy
renyone said:Is there a way to select several columns easily ?
multi-selection is not a feature of the chart control. however, with some effort you can do this using a FillSceneGraph event handler. In this event, you can add whatever visuals you need to indicate selection.
