When using the TilePanel control and all the tiles get repositioned to the side because you have selected one to display as a large tile, I was wondering is there a property to set how wide the section of the TilePanel where all the small tiles display?
Troy
It's done successfully.
If you want further explanation , you can email me matrikaghimire26@gmail.com :)
private void tile_panel_A_TileStateChanging(object sender, Infragistics.Win.Misc.TileStateChangingEventArgs e) { e.Cancel = true; tile_panel_B.clear();
//get the detail of tile as : // Infragistics.Win.Misc.UltraTile some_time= e.Tile;
// create new tile _tile Infragistics.Win.Misc.UltraTile T = new Infragistics.Win.Misc.UltraTile(); //enter tile details and add controls to the tile
//add new tile to tile_panel_B tile_panel_B.Tiles.Add(_tile);
I'm also facing same problem. It's sad to know they haven't provided solution for that. But , I think , You can use a trick. use 2 pannels A and B. place small tiles in pannel A and maximized tile in B. when some tile in A is maximized, remove previous tile from B and add the tile in B which is maximized in A.
set width of A as you required for the small tiles width and set width of B as you required for large tile.
I've also not tested this, I'll inform you if I succeed.
Please inform if you get any other solution.
Thank you
We currently do not support this functionality. If you want you may submit a feature request for this event on the link below : http://devcenter.infragistics.com/protected/requestfeature.aspx
Stefaniya
I have the exact same request ... I would expect that if I set a maximumsize on one tile the other tiles would auto-resize to the maximum available size ...
Wim
I have created the following support ticket for you:CAS-49758-1WHWG8. I will update you there and here.
