Please reference to DevExpress.Net
1. Column Band is used to group Column, it is similar to the Column header BUT the end user move the Column Band , all Columns belong to it will be moved, and Columns belong to Column band and only be moved in the Column band range.
2. now has to implement the page-row navigator ourself, it's very difficult.
because i've thought that the wingrid had one. Now that i know the wingrid does not have a row navigator i'll usebindingnavigator..
Regards
No, not built-in to the grid. But why don't you use the BindingNavigator component that is part of the DotNet framework?
Hi Mike,
Exist a "row-navigator" in the wingrid? something like this
thank you.
UltraWinGrid does not have this feature. You can Request a Feature or Component
