475
Simulating a key press on UltraGrid
In my application some key presses are captured by accelerators and translated into the appropriate command.  For instance CTRL+C is mapped to the ID_EDIT_COPY command.  I am able to capture these commands in my C# UltraGrid wrapper assembly and get them to the grid by calling for instance....
m_grid.PerformAction(Infragistics.Win.UltraWinGrid.UltraGridAction.Copy);
However, I need to be able to simulate clicking the Delete key in the grid when it is in edit mode.  I do not see any actions in the PerformAction method that would send a key press to the grid.
I have tried using the PostMessage API call with WM_KEYDOWN but this caused the grid to hang ?
Any recommendations ?
