Hello, developers!
I was confronted by difficulties...
I have ultragrid. I use EditorWithText for every cell, for displaying formatting cell's data in dependency of it data.
(If cell value >= 1000, then I round off to integer: 14050.0234 = 14 050,
if cell value <1000 and >= 100, then I round to one decimal places: 925.441 = 925.4,
if cell value <100 and >= 10, then I round to two decimal places: 55.123 = 55.12,
and if cell value <10, then I round to three decimal places: 1.057923 = 1.057)
For example:
DefaultEditorOwnerSettings settings = new DefaultEditorOwnerSettings();
settings.Format = format; // Some format ("N0", "N1", "N2", "N3")
DefaultEditorOwner editorOwner = new DefaultEditorOwner(settings);
EditorWithText editor = new EditorWithText(editorOwner);
cell.Editor = editor;
In my case, I need select some foreign currency, and cell's data must be displaying data in selected currency.
On the one part, I need dislaying formatting value in grid's cells in accordance with selected currency, on the other part, i need save original value in Cell.Value
For example, I have cell.value = 125.02 (rubles), if i select USD (let 1 dollar = 30 Rubles), then cell must display 3 750 (125.02 * 30 = 3750.6) notably, I want display 3 750 (formatted value), but really cell value must be 125.02
I find partial solution of this problem - I use UltraGrid.DisplayLayout.ValueLists:
// In main form constructor
ultraGrid.DisplayLayout.ValueLists.Add("USD");
ultraGrid.DisplayLayout.ValueLists.Add("EUR");
ultraGrid.DisplayLayout.ValueLists["USD"].DisplayStyle = ValueListDisplayStyle.DisplayText;
ultraGrid.DisplayLayout.ValueLists["EUR"].DisplayStyle = ValueListDisplayStyle.DisplayText;
// in UltraGrid's InitializeRow event:
for(Int32 i = 0; i < grid.DisplayLayout.Bands[0].Columns.Count; i++)
UltraGridColumn column = grid.DisplayLayout.Bands[0].Columns[i];
if (column.Header.Caption == "Money")
// ValueLists
ValueListItem item = new ValueListItem();
item.DataValue = e.Row.Cells[i].Value;
item.DisplayText = ((double)item.DataValue * 30).ToString();
ugGrid.DisplayLayout.ValueLists["USD"].ValueListItems.Add(item);
settings.Format = //assign format;
editorOwner.MustDisplayFromList(column); // Display data from ValueLists
e.Row.Cells[column].Editor = editor;
break;
In this way, cell's data displaying in concordance with selected currency, but data's format is lose...
in concordance with our example, cell value will display 3750.6
What I do wrong?!
How i can find decision for this problem?
I will very grateful for any help, hint, example, link.
Thanks! :)
P.S.: I use NetAdvantage WinForms 10.1
Sorry for poor English...
Format only affects the cell when it is not in edit mode. When the cell is in edit mode, you can use the MaskInput property to apply a mask.
Hi Mike,
I have a similar problem. I have cell of type decimal formatted to ##,##. But when I got to the cell to edit the value I loose the
format and raw decimal value is showing up on select the cell. What is the way to avoid that?
Many thanks, Mike, for your links!
Brian Fallon"] I attached a C# project that demonstrates how to use the IEditorDataFilter interface to present currency values to the user with the currency units of a specific culture, while maintaining the underlying values in USD.
Many thanks, Brian!
Your project's example very useful for me!!! Thanks!
