660
Editing allowed but no immediate editor?
is it possible to set the UltraListView to a state, where the user is able to edit the items (main column) but didn't get the editor when clicking the item the first time?
It's a bit annoying if you click on an item and get the editor all the time. It's OK on a second click or with F2.
Any solutions/idas?
thanks
Boris
  • 69832
    There is no property setting that will get you this behavior, but you can handle MouseDown, set a timer, and check that timer in MouseUp, then go into edit mode programmatically based on a condition such as whether the item was selected when MouseDown fired. Typically you also handle MouseDoubleClick and kill the timer if that event fires so that a double-click does not cause the item to enter edit mode.
