Is there a way to make tasks not overlap? I have a GanttView with an interval of one month. If I have 2 tasks, one ending 02/15 and the other starting 02/16, the end and the start overlap for the whole month.
I'm using the latest version right now (11.3).
How do you solve that?
I'm using tasks in hour mode.
When the previous task finishes at 07:58 and the next starts at 07:59, then the bars overlap each other (both starting visually at 07h).
Thanks a lot,
Marc
HI,
I am just following up on this issue.
You will be contacted when the feature request has been implemented.
If you have any additonal questions regarding this issue, please feel free to contact me.
Sincerely,
MattDeveloper Support Engineer
HI All,
Feature Rquest FR12512 has been created.
Matt ,
Currently tasks are aligned with the bounds of the time slots which contain the start/end times. If you like you can submit a feature request for the ability to change this and make the tasks offset their edges based on the amount of time between the task's start time and the start time of the first time slot with which it intersects.
