I have various data in ultragrid and I would like to format some data in the cell.
So I have a string:
1234567 890
and I would like to format it in the following way:
123|456|7_._|_|__.__|890
I tried following approach:
UltraGridColumn.MaskInput = "aaa|aaa|aa.a|a|aa.aa|aaa";
UltraGridColumn = MaskMode.IncludeBoth;
The problem is that it does not work as expected. Data are displayed like this:
123|456|7_._|_|_8.90|___
I have found out that the problem is present when string I want to format includes spaces. As long as I remove the spaces everything is fine. I have replaced space with x. String now looks like this:
1234567xxxxxxx890
Formatted string is displayed as expected:
123|456|7x.x|x|xx.xx|890
I have numbers in the sample, but they should be treatet as string. So instead of 1234 I can have abcd.
So my question is what do I do wrong? How do I format string 1234567 890 with spaces to be displayed as 123|456|7_._|_|__.__|890?
Thanks for info. Is there something new about this issue? (http://forums.infragistics.com/forums/t/44070.aspx). Is it planed now for some hotfix release or next release of Infragistics Winforms?
More about this issue can be found here:
It is same issue but support replied to that one.
I have the same problem too. Infragistics v. 9.1. It looks like a problem with spaces. Can somebody help us.
Thanks.
