361
Problems editing a Band 1 cell
I have a grid bound to a DataSet, having 2 tables. Thus the parent table appears as Band 0 and the child table as Band 1.
The Grid constantly receives updates. causing certain rows to be redrawn
Editing the Band 0 grid works fine.
When I try to edit a cell in Band 1, it loses focus when a row update comes in at that level. As a result, the cell doesnt remain in edit mode for too long. How can i prevent this?
When an update comes in, I just update the values in the underlying datatable.
I tried adding this in the grid_InitializeRow event
grid.DisplayLayout.Override.SelectTypeRow = SelectType.None;
but this did nothing.
I also added an event handler:
void grid_BeforeRowDeactivate(object sender, CancelEventArgs e)
            UltraGrid grid = sender as UltraGrid;
            if (grid != null)
                if ( grid.ActiveCell != null)
                    if ( grid.ActiveCell.IsInEditMode)
                        e.Cancel = true;
Even this does not work.
What can i do to retain editor focus in Band 1?
Im using Infragistics 8.1 UltraWinGrid, with all the recent fixes.
