95
Random crashes in UltraWinGrid
We use version 10.1.20101.2027. This happens occasionally when the user closes a window and the dispose method is called. I see there has been reported something similar with the UltraWinToolbars in this thread: http://forums.infragistics.com/forums/p/41053/236401.aspx#236401.
The stack trace follows bellow:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Graphics.GetHdc()
   at System.Windows.Forms.Internal.WindowsGraphics.FromGraphics(Graphics g, ApplyGraphicsProperties properties)
   at System.Windows.Forms.WindowsGraphicsWrapper..ctor(IDeviceContext idc, TextFormatFlags flags)
   at System.Windows.Forms.TextRenderer.MeasureText(IDeviceContext dc, String text, Font font, Size proposedSize, TextFormatFlags flags)
   at Infragistics.Win.DrawUtility.MeasureStringHelper(Graphics gr, String text, Font font, Size layoutArea, StringFormat stringFormat, Int32& charactersFitted, Int32& linesFilled, Boolean returnElementsFitted, GdiDrawStringFlags drawStringFlags)
   at Infragistics.Win.DrawUtility.MeasureStringHorizontalFlowHelper(DrawStringParameters& parameters, Boolean trackCharactersFitted, Int32& charactersFitted, Int32& linesFilled, SizeF& unrotatedLayoutArea, SizeF& unrotatedTextSize)
   at Infragistics.Win.DrawUtility.MeasureStringHorizontalFlow(DrawStringParameters& parameters, Boolean trackCharactersFitted, Int32& charactersFitted, Int32& linesFilled, SizeF& unrotatedLayoutArea, SizeF& unrotatedTextSize)
   at Infragistics.Win.DrawUtility.MeasureStringHelper(DrawStringParameters& parameters, Boolean trackCharactersFitted, Int32& charactersFitted, Int32& linesFilled)
   at Infragistics.Win.DrawUtility.MeasureString(DrawStringParameters& parameters)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.MeasureStringF(Graphics gr, String text, Font font, Int32 maxWidth, StringFormat sf, TextOrientationInfo textOrientation)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.MeasureString(Graphics gr, String text, Font font, Int32 maxWidth, StringFormat sf, TextOrientationInfo textOrientation)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.CalculateFontSize(Font font, String text, Int32 maxWidth, TextOrientationInfo textOrientation)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.CalculateFontHeight(Font font)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.CalculateFontHeight(AppearanceData& appData)
   at Infragistics.Win.UltraWinGrid.UltraGridLayout.get_DefaultFontHeight()
   at Infragistics.Win.UltraWinGrid.UltraGridBand.CalcMinRowHeight()
   at Infragistics.Win.UltraWinGrid.UltraGridBand.GetMinRowHeightHelper(Boolean synchronized)
   at Infragistics.Win.UltraWinGrid.UltraGridBand.get_RowHeightResolved()
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.ResetScrollInfo()
   at Infragistics.Win.UltraWinGrid.ScrollRegionBase.ShowScrollbar(Boolean show, Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.PositionScrollbar(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.RegenerateVisibleRows(Boolean resetScrollInfo)
   at Infragistics.Win.UltraWinGrid.RowScrollRegion.WillScrollbarBeShown(ScrollbarVisibility assumeColScrollbarsVisible)
   at Infragistics.Win.UltraWinGrid.ScrollRegionBase.WillScrollbarBeShown()
   at Infragistics.Win.UltraWinGrid.ViewStyleBase.AddBandHeaders(ColScrollRegion csr, UltraGridBand band)
   at Infragistics.Win.UltraWinGrid.ViewStyleSingle.RecreateHeaderList(ColScrollRegion csr)
   at Infragistics.Win.UltraWinGrid.ColScrollRegion.RegenerateVisibleHeaders()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetricsHelper()
   at Infragistics.Win.UltraWinGrid.ColScrollRegionsCollection.InitializeMetrics()
   at Infragistics.Win.UltraWinGrid.UltraGridBase.Set_ListManager(Object newDataSource, String newDataMember)
   at Infragistics.Win.UltraWinGrid.UltraGridBase.set_DataSource(Object value)
   at Infragistics.Win.UltraWinGrid.UltraGridBase.DataSource_Disposed(Object sender, EventArgs e)
   at System.ComponentModel.Component.Dispose(Boolean disposing)
   at System.Windows.Forms.BindingSource.Dispose(Boolean disposing)
   at System.ComponentModel.Component.Dispose()
   at System.ComponentModel.Container.Dispose(Boolean disposing)
   at System.ComponentModel.Container.Dispose()
