The scenario is that i have two vertical panes ( 15% and 85%) . In 15% panel , i have two buttons and in 85% panel i have two win grids. one clicking the button in 15%panel ,
the two grids (one below another) in 85 % panel gets minimized as per the functionality. intially the allignment of the grids are proper. but when i minmize both grids, the allignment get disrupted
I had tried everything. but i cant figure why misalignment happens on minimazation of the grids.
i can give more info , if needed.
Thanks and Regards,
Parthiban S
Hi Parthiban,
I'm afraid that I do not understand the issue. What exactly do you mean by "alignment"? Alignment of what?
Can you post a small sample project demonstrating the behavior you are getting?
