It is ok,
Dimi, Thank you for your help!
Hello, If you have stored your Images in to the database and when you get them form there as images you just need to set the style of the column to Image You can find more details here:http://help.infragistics.com/NetAdvantage/WinForms/2010.1/CLR2.0/?page=Infragistics2.Win.UltraWinGrid.v10.1~Infragistics.Win.UltraWinGrid.ColumnStyle.htmlif you simply has the path of the image you can assign the image directly to the value by recreating it. You can find similar article here:http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=1749I hope this helps.Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
