Dear all,
plz take a look at the attached screenshot (column day no 2 especially). We have a calendar for production shifts and we noticed that there is a difference in the text orientation whetever the appointment is just 1 hour, more than 1 hour or rolling over to the next day.
So we know that it comes from either putting Text and description one one line or on a second one if space permits it. However, the orientation should be somehow consistent.
Second issue: Can the header display at least 1 letter of the weekday instead of falling back to only numbers for many columns? For the shift views, we normally look at as much columns as possible.
thanks kind regards
Florian
The benefit of doing so is that you get a formal notification when the fix is released. If you don't report it you just have to find out when the next service release is, and if it contains that fix. I can tell you that I just fixed it and checked it in, but the rest of the process is out of my hands (verification, additional testing, notifying customers, etc).
Brian,
thanks, Is there a need to file a separate bug report?
regards Florian
The discrepancy in indentation is a bug and will be addressed in a future release.
You can change the day header text by handling the InitializeVisibleDay event and setting the VisibleDay.Text property.
