I think there is a serious bug in the group by functionality. I am using 2010 volume 1 with the latest service pack release (2027).
Basically, the sorting is completely buggered if you group by two columns (one string and one date time).
Use the following code to create a datatable and assign it to the grid. Group by the String column and then the DateTime column and see what happens. There are loads of rows for each group even though there should be one for each string and DateTime.
if (_dataLarge == null) { _dataLarge = new DataTable { Locale = CultureInfo.InvariantCulture }; _dataLarge.Columns.Add("Counter", typeof(string)); _dataLarge.Columns.Add("Int", typeof(int)); _dataLarge.Columns.Add("Group", typeof(double)); _dataLarge.Columns.Add("String", typeof(string)); _dataLarge.Columns.Add("DateTime", typeof(DateTime)); Random random = new Random(); string[] str = new[] { "abcdefghijklm", "nopqrstuvwxyz" }; for (int i = 0; i < 100000; i++) { _dataLarge.Rows.Add(i.ToString(CultureInfo.InvariantCulture), random.Next(1, 10000000), random.Next(0, 9), str[i%2], DateTime.Now.AddDays(random.Next(0, 10))); } }
Here are the properties setup on the grid:
appearance4.BackColor = System.Drawing.SystemColors.Window; appearance4.BorderColor = System.Drawing.SystemColors.InactiveCaption; resources.ApplyResources(appearance4.FontData, "appearance4.FontData"); resources.ApplyResources(appearance4, "appearance4"); appearance4.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Appearance = appearance4; this._performanceResizeStandardGrid.DisplayLayout.BorderStyle = Infragistics.Win.UIElementBorderStyle.Solid; this._performanceResizeStandardGrid.DisplayLayout.CaptionVisible = Infragistics.Win.DefaultableBoolean.False; appearance1.BackColor = System.Drawing.SystemColors.ActiveBorder; appearance1.BackColor2 = System.Drawing.SystemColors.ControlDark; appearance1.BackGradientStyle = Infragistics.Win.GradientStyle.Vertical; appearance1.BorderColor = System.Drawing.SystemColors.Window; resources.ApplyResources(appearance1.FontData, "appearance1.FontData"); resources.ApplyResources(appearance1, "appearance1"); appearance1.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.GroupByBox.Appearance = appearance1; appearance2.ForeColor = System.Drawing.SystemColors.GrayText; resources.ApplyResources(appearance2.FontData, "appearance2.FontData"); resources.ApplyResources(appearance2, "appearance2"); appearance2.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.GroupByBox.BandLabelAppearance = appearance2; this._performanceResizeStandardGrid.DisplayLayout.GroupByBox.BorderStyle = Infragistics.Win.UIElementBorderStyle.Solid; appearance3.BackColor = System.Drawing.SystemColors.ControlLightLight; appearance3.BackColor2 = System.Drawing.SystemColors.Control; appearance3.BackGradientStyle = Infragistics.Win.GradientStyle.Horizontal; appearance3.ForeColor = System.Drawing.SystemColors.GrayText; resources.ApplyResources(appearance3.FontData, "appearance3.FontData"); resources.ApplyResources(appearance3, "appearance3"); appearance3.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.GroupByBox.PromptAppearance = appearance3; this._performanceResizeStandardGrid.DisplayLayout.MaxColScrollRegions = 1; this._performanceResizeStandardGrid.DisplayLayout.MaxRowScrollRegions = 1; appearance12.BackColor = System.Drawing.SystemColors.Window; appearance12.ForeColor = System.Drawing.SystemColors.ControlText; resources.ApplyResources(appearance12.FontData, "appearance12.FontData"); resources.ApplyResources(appearance12, "appearance12"); appearance12.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.ActiveCellAppearance = appearance12; appearance7.BackColor = System.Drawing.SystemColors.Highlight; appearance7.ForeColor = System.Drawing.SystemColors.HighlightText; resources.ApplyResources(appearance7.FontData, "appearance7.FontData"); resources.ApplyResources(appearance7, "appearance7"); appearance7.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.ActiveRowAppearance = appearance7; this._performanceResizeStandardGrid.DisplayLayout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.Dotted; this._performanceResizeStandardGrid.DisplayLayout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.Dotted; appearance6.BackColor = System.Drawing.SystemColors.Window; resources.ApplyResources(appearance6.FontData, "appearance6.FontData"); resources.ApplyResources(appearance6, "appearance6"); appearance6.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.CardAreaAppearance = appearance6; appearance5.BorderColor = System.Drawing.Color.Silver; appearance5.TextTrimming = Infragistics.Win.TextTrimming.EllipsisCharacter; resources.ApplyResources(appearance5.FontData, "appearance5.FontData"); resources.ApplyResources(appearance5, "appearance5"); appearance5.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.CellAppearance = appearance5; this._performanceResizeStandardGrid.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.EditAndSelectText; this._performanceResizeStandardGrid.DisplayLayout.Override.CellPadding = 0; appearance9.BackColor = System.Drawing.SystemColors.Control; appearance9.BackColor2 = System.Drawing.SystemColors.ControlDark; appearance9.BackGradientAlignment = Infragistics.Win.GradientAlignment.Element; appearance9.BackGradientStyle = Infragistics.Win.GradientStyle.Horizontal; appearance9.BorderColor = System.Drawing.SystemColors.Window; resources.ApplyResources(appearance9.FontData, "appearance9.FontData"); resources.ApplyResources(appearance9, "appearance9"); appearance9.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.GroupByRowAppearance = appearance9; resources.ApplyResources(appearance11, "appearance11"); resources.ApplyResources(appearance11.FontData, "appearance11.FontData"); appearance11.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.HeaderAppearance = appearance11; this._performanceResizeStandardGrid.DisplayLayout.Override.HeaderClickAction = Infragistics.Win.UltraWinGrid.HeaderClickAction.SortMulti; this._performanceResizeStandardGrid.DisplayLayout.Override.HeaderStyle = Infragistics.Win.HeaderStyle.WindowsXPCommand; appearance10.BackColor = System.Drawing.SystemColors.Window; appearance10.BorderColor = System.Drawing.Color.Silver; resources.ApplyResources(appearance10.FontData, "appearance10.FontData"); resources.ApplyResources(appearance10, "appearance10"); appearance10.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.RowAppearance = appearance10; this._performanceResizeStandardGrid.DisplayLayout.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.False; appearance8.BackColor = System.Drawing.SystemColors.ControlLight; resources.ApplyResources(appearance8.FontData, "appearance8.FontData"); resources.ApplyResources(appearance8, "appearance8"); appearance8.ForceApplyResources = "FontData|"; this._performanceResizeStandardGrid.DisplayLayout.Override.TemplateAddRowAppearance = appearance8; this._performanceResizeStandardGrid.DisplayLayout.ScrollBounds = Infragistics.Win.UltraWinGrid.ScrollBounds.ScrollToFill; this._performanceResizeStandardGrid.DisplayLayout.ScrollStyle = Infragistics.Win.UltraWinGrid.ScrollStyle.Immediate; this._performanceResizeStandardGrid.DisplayLayout.ViewStyleBand = Infragistics.Win.UltraWinGrid.ViewStyleBand.OutlookGroupBy; resources.ApplyResources(this._performanceResizeStandardGrid, "_performanceResizeStandardGrid"); this._performanceResizeStandardGrid.Name = "_performanceResizeStandardGrid";
This bug is fixed in v10.2 and in the July service release. I beleive it was posted on July 7th or possibly 8th.
If you are using this service release and the problem is still occurring, then my best guess is that either the solution you are running was not properly updated and is still using the old version, or else you are experiencing some other issue that is similar to the one that was fixed.
Saltzman!!!!!!!
I concur with omara500. This is a major bug and should have been fixed. If you state it is going to be fixed in July, then it should be fixed.
This bug has not been fixed in the July service pack release. This is the last time we use Infragistics for anything.
