Having trouble getting off the ground with the WinSplitter control. Can you give me some hints as to how to use the control or point me to some decent documentation (the docs I've found seem very limited). The little video was NOT very helpful. Thanks.
Check out the following link to WinForm documentation:
http://help.infragistics.com/NetAdvantage/WinForms/2010.2/CLR2.0/
This one will take you straight to WinSplitter documentation:
http://help.infragistics.com/Help/NetAdvantage/WinForms/2010.2/CLR2.0/html/WinSplitter.html
Is anyone from Infragistics out there? Need to help here. I'm an experienced developer but your Splitter control is not resonating with me. Any help would be appreciated. Thanks.
