1425
Is Manual CalcManager 100% Synchronous?
Hi All,
Although I'd ideally like a response from someone from the Infragistics support team, I thought I'd post this question here in case it may be helpful to others (or if anyone else has any information on this)...
I am currently using an UltraGrid bound to a DataTable with a CalcManager that are all constructed and used on a seperate thread. The CalcManager is Manual and deffered calculations are disabled.
Whenever a change is made to a seperate UltraGrid (formulas added, removed edited) I intend to replicate this in a seperate DataTable by simply applying the formulas to this UltraGrid on a seperate thread and performing a ReCalc on it's CalcManager.
This has been working fine, except we are occasionally experiencing a cross-threading issue. It has been difficult to determing the cause (especially as the exception thrown does not name the control or object that was cross-threaded). After clearing up the code a bit and ensuring all GUI controls are accessed on the thread that they were created on, we are still seeing this issue.
My question is: if a CalcManager is Manual, deffered calculations are disabled and it is created, assigned and modified on the thread that the UltraGrid it is assigned to was created on, can I be certain that if I call myCalcManager.ReCalc(-1) it will: (a) Hang until all cells in the grid are up-to-date, and (b) the CalcManager is thread-safe here and is not delegating tasks on other threads behind the scenes?
I would like to rule this out of the possible issues, so any clarification would be greatly appreciated!
Cheers,
Richard
P.S. I know this isn't really the place for it as it's more of a general Windows issue, but does anyone know why the Control/object's name that is being cross-threaded would not appear in the exception? Is it simply the control does not have a name?
