I want to bind an UltraGrid to a generic list of strings using List<string> (c# generic class).
I've set up a BindingSource.DataSource to my List<string> object, but when I hook it up and run my program, the UltraGrid shows a single column bound to the Length property showing the Lengths of my strings instead of showing me the actual list of string data.
If I set a System.Windows.Forms.Listbox or ComboBox to use the same BindingSource, I get the expected list of strings shown.
Why can't an UltraGrid do the same thing? I couldn't find any help on this seemingly simple thing.
Hi Mike,
Thanks a lot for the quick response. I tried to bind the grid with UltraWinDataSource correctly using ILists for the childbands. Thanks for your help!
-Bhargavi R.
Hi Bhargavi,
You can't bind each band in the grid individually. You have to create a DataSource, such as a DataSet or UltraDataSource that has a hierarchical structure of data. If you are using a DataSet, which is probably the most common data source, then you need to defined RelationShips between the tables. I'm sure Microsoft has documentation on creating hierarchical data relationships with a DataSet.
Here's a bunch of KB articles to get you started:
HOWTO:Bind to hierarchical data source using Northwind Part 1
HOWTO:Bind UltraWinGrid to program generated hierarchical data Part 1
HOWTO:Bind UltraWinGrid to a DataSet
Could you please tell how to bind if there are more than one band in the grid. I want to bind the grid with separate typed lists for each band. I am trying different ways but unable to bind the grid correctly.
Any help is greatly appreciated!
Thank you,
Bhargavi R.
No problem, i'll get back to you here once i get some time to test this out...
Thanks!
