When using the Ultra Toolbars Manager control in Ribbon’s Office 2007 style and adding Button,
after maximizing the entire window,
if I click the button to pop up a model window form.ShowModal ()
or a dialog box MessageBox.Show (..),
the whole window will appear flashing ( in the Ribbon section)
my system is XP SP2
under win7 is normally
is this a bug?
thanks Stefaniya and Mike Dour~
I have noticed that you have a created case on this issue ( CAS-46732-Z4SJSY ). I couldn't reproduce this behavior with version 10.1.2027. I will test and with 8.2. and will inform you in the support ticket.
- Stefaniya
the components version is 200802
This sounds like it is probably a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
