665
Unable to view UltraExplorerBar Designer window
First off I'm using Windows 7, VS 2008, with Infragistics 2009.2.
Dual Monitor setup. If I've posted this in the wrong location. Please advise where it should be posted.
This anomaly occurs with several of your controls.  When I'm at work everything works fine using two monitors, but when I take my laptop home and then try to access any of your popup windows associated with your controls and the last time I viewed that window on the other monitor, I cannot move that window to the laptop screen.  Do you have a work around?  Windows will only move a form and/or window if its a program window.
If  I forget to set your popup windows on the laptop screen I'm toast when I try again at home with only the one monitor.  Any help would greatly be appreciated.  (and yes another monitor at home would help, but I'm not there yet).
Patrick
