i have a grid witch i set the CellClickAction property to CellSelect but when i click on the cell border or the row border the entire row is selected.
how can i avoid that?
Sorry about that. I meant "Fixed". "AutoFixed" probably works, too.
You might also need to set AllowRowLayoutCellSizing and AllowRowLayoutLabelSizing, but I think these will fall back to the RowSizing property, anyway.
there is no None in RowSizing enum.
Try setting grid.DisplayLayout.Override.RowSizing to None.
your code works very well but it enable the user to re size the row height .
is there is a way to disable that?
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { e.Layout.Bands[0].RowLayoutStyle = RowLayoutStyle.ColumnLayout; }
