125
To change color to bars
Hello, I hope that they are nice, I mexican.
how I can change the color of the bars of my chart For example
If my bar 1 his value is of 50 to put it of red color, If it is 70 of blue color, etc.
I wait I have explained, I am grateful in advance for his help, Regards.
  • 2406
    You could use the FillSceneGraph event of the chart to loop through all chart elements and if it is a bar, you could change its color (by the PE element) depending on its value. Here is a sample code:
    UltraChart ultraChart1;
    public Form1()
        InitializeComponent();
        ultraChart1 = new UltraChart();
        ultraChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.BarChart;
        this.ultraChart1.FillSceneGraph += new FillSceneGraphEventHandler(ultraChart1_FillSceneGraph);
        ultraChart1.DataSource = GetTable();
        ultraChart1.DataBind();
        this.Controls.Add(ultraChart1);
    void ultraChart1_FillSceneGraph(object sender, FillSceneGraphEventArgs e)
        foreach (Primitive p in e.SceneGraph)
            Box bar = p as Box;
            if (bar != null)
                NumericDataPoint dp = bar.DataPoint as NumericDataPoint;
                if (dp != null)
                    if (dp.Value == 50)
                        bar.PE.Fill = Color.Red;
                    if (dp.Value == 70)
                        bar.PE.Fill = Color.Blue;
