3045
Can a form with DockManager be used as MDITab Child?
FACTS:
IG Controls Version: 9.2.20092.2058
MDITab parent already has DockManager
MDITab parent uses a Ribbon
MDITab child has a DockManager
MDITab child has a Ribbon set to Merge
The child form doesn't render correctly when added as MDITab child. Is this a limitation?
  • 44743
    No, this should work. The only thing to note here is dock panes from the mdi child will not be able to dock to the edges of the mdi parent. Other than that, everything should work. What is the rendering issue you are seeing? Can you post a screenshot?
