4165
How to set Toolbar Width
Hello.
How can I control the width of the rows in the toolbar manager or the width of the toolbars themselves?
Thanks.
  • 20872
    Suggested Answer
    It is not recommended to change the size of the Toolbar elements, but it is possible with a CreationFilter. I have created a small sample and if you use the following CreationFilter you will be able to manipulate the width :
      class CreationFilterToolbarWidth : IUIElementCreationFilter
            #region IUIElementCreationFilter Members
            public void AfterCreateChildElements(UIElement parent)
                 UltraToolbarsDockAreaUIElement toolbarParent = parent as UltraToolbarsDockAreaUIElement;
                 if (toolbarParent != null)
                    //looping through the Toolbars to make them with Equal width
                    foreach(ToolbarUIElement uiEL in toolbarParent.ChildElements)
                     //Setting the desired width to each of the Toolbars
                     uiEl.Rect = new Rectangle(uiEl.Rect.X, uiEl.Rect.Y, 500, uiEl.Rect.Height);
            public bool BeforeCreateChildElements(UIElement parent)
                return false;
            #endregion
     And after that you just need to assing an instance of this class to your UltraToolbarsManager component like :
     ultraToolbarsManager1.CreationFilter = new CreationFilterToolbarWidth();
    Please let me know if you have any other questions.
