340
Sum column based on another columns value
i have a grid with two columns - FeeActive and FeeAmount.  FeeActive is a boolean/checkbox.  FeeAmount a decimal/currency.  I want to sum only the FeeAmounts that are Active.  Why will the following formula not work?
grid.DisplayLayout.Bands(0).Summaries(
"FeeAmount").Formula = "sum(if([FeeActive]=0,0,[feeAmount] ))"
I have used the fallback plan of creating a separate unbound calc column to sum on but this seems more than is necessary.
Any help making this work or understanding why it will not would be much appreciated.
  • 469350
    Verified Answer
    Formulas are context-sensitive. So if you put a formula in a grid cell, then [FeeActive] has a context of the row the formula is in and it will interpret this as the value of the [FeeActive] cell in the same row.
    But the same token in a summary, doesn't have a context of a cell. The summary belongs to the entire band. So [FeeActive] in this case refers to an entire column. Therefore, the IF function won't work, because an entire column is not a boolean value.
    What you have to do in a case like this is use two formulas. What I would do is create an unbound column and put a formula on it which is very much like the one you have here. The column formula will result in either the [FeeAmount] or 0 depending on the value of [FeeActive]. Then you can sum the unbound column for your summary.
