60
UltraChart DataSeries using a DataTable populated by calling a Stored Procedure
How do you create a data series when the Ultrachart is bound to a datatable that was
populated by calling a stored procedure?
  • 995
    I believe you already have DataTable from DataSource, so you can use Data property to create a series from this table: for example for the NumericSeries:
            NumericSeries series = new NumericSeries();
           series.Label = "Series A";
           DataTable table = SOME TABLE FROM DB
           series.Data.DataSource = table;
           series.Data.LabelColumn = "Label Column";
           series.Data.ValueColumn = "Value Column";
           return series;
