Hi, is it posible to disable the tooltip text for only one column in the ultragrid control? I found how to do it to the entire grid but not for a single column, please advise.Thanks
I have investigated your issue and, I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 68551. The next step will be for a developer to review my investigation and confirm my findings or to offer a fix, or other resolution.
Please fill free to ask me if you have other questions
If you want to show tooltip text for selected columns, I suggest you to disable the tooltip text of UltraWinGrid. You can do this via disigner or with this piece of code:
ultraGrid1.DisplayLayout.Override.TipStyleCell =
TipStyle.Hide;
then write this small piece of code in your applications:
1. Get in your application: ultraToolTipManager;
2. Get the event “MouseEnterElement” of UltraWinGrid
3. Add the code below:
private void ultraGrid1_MouseEnterElement(object sender, Infragistics.Win.UIElementEventArgs e) { if (e.Element is CellUIElement && ((CellUIElement)e.Element).Cell.Column.Key == "Type your column key") { ultraToolTipManager1.ToolTipTitle = ((CellUIElement)e.Element).Cell.Text; ultraToolTipManager1.ShowToolTip(ultraGrid1); } }
Sincerely
Georgi
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
