90
PieChart3D: how to display integer values
I am using UltraChart as PieChart3D.  I set it to display values instead of percentages.  The problem is that the values are counts, but I am getting 2 decimal points.
I tried to change the FormatString to <DATA_VALUE:00>.  It looked correct on the designer but did not work when I run the application.
How to make the PieChart display integers.
Nuha
  • 12875
    Hi Nuha,
    Glad you were able to find the answer.   Your FormatString looked correct to me.  You should be able to use “00” or “##” to generate a 2 digit label.
    “00” would cause the value to be rounded to the nearest digit preceding the decimal.  For example, formatting 21.5 with "00" would result in the value 22.
    A “##” format string would cause the value to be truncated to the nearest digit preceding the decimal. For example, formatting 21.5 with "##" would result in the value 21.
    Let me know if you have any other questions.
    Marianne
  • 90
    I found the problem. I had a line in my code to reset the format.  Now it works.
