I have a composite chart that I want to be able to scroll the X axis. I have set the following:
ultraChart1.Axis.X.ScrollScale.Visible = true;
ultraChart1.Axis.X.ScrollScale.Scroll = 0;
but that does not seem to work. The composite chart contains a single 2D Line chart (for now).
PERFECT! Thanks so much!
just set:
this.ultraChart1.LineChart.TreatDateTimeAsString = false;
You can provide a custom format string. Here in the screen capture I think the format is just the localized presentation of the default format.
Hope that helps.
What code did you use to get you dates to appear like they do in your chart screen capture? I am creating similar line numeric time series but have not been able to get the dates to display. Thanks for any advice.
Unfortunately, there isn’t a workaround for that. You can submit a feature request for this here:
http://devcenter.infragistics.com/protected/requestfeature.aspx
