I have just tried to run the toolbox utility:
Infragistics2.ToolboxUtility /v 8.1
It said:
Begin processing NetAdvantage version 8.1
VS: 8.0Removing Tabs...Removing tabs...COMPLETE
It then gave the following error:
An error occurred while attempting to add the Infragistics components to the tool box.
and generated the following log file:
01:05:36 - Params: /v 8.1 01:05:36 - PUBLIC: Begin processing NetAdvantage version 8.101:05:36 - Beginning to process VS v701:05:36 - Getting Type for ProgID: VisualStudio.DTE.701:05:36 - Type for ProgID: VisualStudio.DTE.7 - null01:05:36 - Beginning to process VS v7.101:05:36 - Getting Type for ProgID: VisualStudio.DTE.7.101:05:36 - Type for ProgID: VisualStudio.DTE.7.1 - null01:05:36 - Beginning to process VS v8.001:05:36 - Getting Type for ProgID: VisualStudio.DTE.8.001:05:36 - Creating type: System.__ComObject01:05:42 - PUBLIC: VS: 8.001:05:42 - Getting Toolbox Window01:05:42 - Getting Toolbox01:05:42 - Getting Toolbox Tabs01:05:42 - Getting Install Directory.(netAdvantageVersion: 8.1, target: 8.0, type: 0, CLR: CLR2x)01:05:42 - Attempting to get NetAdvantageJP key 101:05:42 - NetAdvantageJP key is null01:05:42 - minimumVersion: 6.201:05:42 - Getting VersionKey: found01:05:42 - Getting Install Directory Inner. (versionKey: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full, target: 8.0, type: 0, netAdvantageVersion:8.1, CLR:CLR2x)01:05:42 - Getting WEB key01:05:42 - Found WEB key01:05:42 - Getting CLR2x key01:05:42 - Found CLR2x key01:05:42 - Processing installed version: Version8.101:05:42 - Version Not installed: Version8.101:05:42 - GetInstallDirectory Inner returns: ''01:05:42 - Install directory not found.01:05:42 - GetInstallDirectory returns: ''01:05:42 - Getting Install Directory.(netAdvantageVersion: 8.1, target: 8.0, type: 1, CLR: CLR2x)01:05:42 - Attempting to get NetAdvantageJP key 101:05:42 - NetAdvantageJP key is null01:05:42 - minimumVersion: 6.201:05:42 - Getting VersionKey: found01:05:42 - Getting Install Directory Inner. (versionKey: HKEY_CLASSES_ROOT\Infragistics\NetAdvantage\Net\Full, target: 8.0, type: 1, netAdvantageVersion:8.1, CLR:CLR2x)01:05:42 - Getting WIN key01:05:42 - Found WIN key01:05:42 - Getting CLR2x key01:05:42 - Found CLR2x key01:05:42 - Processing installed version: Version8.101:05:42 - Got reg key for installed version: Version8.101:05:42 - Getting InstallDirectory from registry for version: 8.101:05:42 - GetInstallDirectory Inner returns: 'C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 1 CLR 2.0\'01:05:42 - Install directory: 'C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 1 CLR 2.0\' found.01:05:42 - GetInstallDirectory returns: 'C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 1 CLR 2.0\'01:05:42 - PUBLIC: Removing Tabs...01:05:42 - PUBLIC: Removing tabs...COMPLETE01:05:42 - winPath: C:\Program Files\Infragistics\NetAdvantage for .NET 2008 Vol. 1 CLR 2.0\Windows Forms\Bin01:05:42 - webPath: 01:05:42 - Register MessageFilter01:05:42 - Getting temp file name01:05:42 - Got temp file: 'tmp5803'01:05:42 - Got full temp file: 'C:\Users\davidb\AppData\Local\Temp\tmp5803'01:05:42 - Getting Solution01:05:42 - Getting template project01:05:43 - EXCEPTION: System.IO.FileNotFoundException Source: Message: The language specified is not supported by any of the installed packages. Stack Trace: at EnvDTE80.Solution2.GetProjectTemplate(String TemplateName, String Language) at TBUtility.ToolboxUtilityManager.AddTabs(DTE _dte, String target, Window _tbWindow, ToolBoxTabs _tbTabs, String webInstallDir, String winInstallDir, String winTabName, String webTabName) at TBUtility.ToolboxUtilityManager.ProcessArguments()01:05:43 - dte.Quit
Nothing was added to the toolbox. Is there anything I'm doing wrong?
BCCollins said:I now have this problem and those above links are dead.
Here are updated links from the online help of NetAdvantage for .NET (Windows Forms) 2009 Volume 2:
Running the Toolbox Utilityhttp://help.infragistics.com/Help/NetAdvantage/WinForms/2009.2/CLR2.0/html/Introduction_Running_the_Toolbox_Utility.html
Using the Choose Items Dialog Boxhttp://help.infragistics.com/Help/NetAdvantage/WinForms/2009.2/CLR2.0/html/Introduction_Using_the_Choose_Toolbox_Items_Dialog_Box.html
Dragging Assemblies from the Bin Folderhttp://help.infragistics.com/Help/NetAdvantage/WinForms/2009.2/CLR2.0/html/Introduction_Dragging_Assemblies_from_the_Bin_Folder.html
I now have this problem and those above links are dead. What do I do?
for the record, my Infragistics Toolbox items unregistered themselves on their own out of the Visual Studio 2008 Toolbox.
These articles are *not* a fix; the installation is broken.
what a load of crap -
fix the installation
HI
Here is a help link to adding controls to the Toolbox
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Introduction_Using_the_Choose_Toolbox_Items_Dialog_Box.html
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Introduction_Dragging_Assemblies_from_the_Bin_Folder.html
