Hello!
If grag toolbar on another monitor exception occurs:
--------------------------- Error --------------------------- 1) Exception Information -------------------------------------------------- Exception Type: System.IndexOutOfRangeException Message: Index was outside the bounds of the array. Data: System.Collections.ListDictionaryInternal TargetSite: Int32 DockColumnIndexFromDragPoint(Infragistics.Win.UltraWinToolbars.UltraToolbar, System.Drawing.Point, Int32, Int32, Int32) HelpLink: NULL Source: Infragistics2.Win.UltraWinToolbars.v8.1 StackTrace Information -------------------------------------------------- at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockArea.DockColumnIndexFromDragPoint(UltraToolbar toolbar, Point point, Int32 dockRowIndex, Int32 currentRowIndex, Int32 currentColumnIndex) at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnDragToolbarMoveHelper() at Infragistics.Win.UltraWinToolbars.UltraToolbarsManager.OnDragToolbarMove() at Infragistics.Win.UltraWinToolbars.UltraToolbarsDockAreaUIElement.OnMouseMove(MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseMoveHelper(Object sender, MouseEventArgs e) at Infragistics.Win.ControlUIElementBase.ProcessMouseMove(Object sender, MouseEventArgs e) at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e) at Infragistics.Win.UltraControlBase.OnMouseMove(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseMove(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) --------------------------- ОК
Any suggestions?
Hello Tom,
I have created the following case for you: CAS-75631-XHMYPM
It seems that were not able to reproduce this issue in our testing environment. If you are still able to reproduce it I would like to ask you for a small sample doing so, or the specific steps that I should follow in order to reproduce it here.
You could provide the details here , or through the case that I have created for you.
If you have any other questions please do not hesitate to contact us.
same bug with 2011 Vol1 (11.1.20111.2042).
Do you plane to correct this issue ?
Tom
I have created the following support ticket CAS-47105-4LG73L. I will inform you about the progress of this issue there.
- Stefaniya
This looks like it is probably a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
