80
Using dataview and dataviewmanager
Another approach for filtering data I used was the dataview, setting the rowfilter,  the ultragrid works well when I assign a dataview as the datasource of the ultragrid, it even shows the child rows too. The problem is that I want to filter also the childrows, so the next approach is to use the dataviewmanager. What i don't get is that when I assign the dataviewmanager as the datasource of the ultragrid, there is no result, no change at all, why is this? I don't get it, it should work, that's what dataviewmanager for or am I wrong here?
Any help will be appreciated, thx in advance.
  • 975
    Your question is old, but maybe others will be asking, I did. I got started with this same effort with an article by Martin Zahn at this link:
    http://www.developerfusion.com/article/4703/filtering-and-sorting-in-adonet/4/
    I wanted to filter the contents of band[1] of a grid to show just rows within a date range:  (This is just test code so it doesn't do exactly that, but you'll get the idea)
    DataViewManager viewManager = new DataViewManager(MyDataset);
    // Loop through the DataViewSettings and set Sort
    // or Rowfilter for each Table individually
    String myTable;foreach (DataViewSetting myDVS in viewManager.DataViewSettings)
    // Set Default Sort Order = Primary Key for all Tables
    myDVS.ApplyDefaultSort = true;
    // Set individual Sort and Rowfilter ...
    myTable = myDVS.Table.ToString();
    if (myTable == "DTRevExpBizSizeDetailOnly")
    myDVS.RowFilter =
    "proj_start_date > '01/10/2007'";
    MyUltraGrid.DataSource = viewManager;
    Bill
