20
Cells in wingrid not editable when application is used in Citrix environment
Dear All,
I have a application using Infragistics Wingrid. I am using Infragistics Netadvantage 2005 Volume 3. The Grid becomes uneditable when used in Citrix environment. The valuelist columns (drop downs in grid) works perfectly fine when used with mouse. But the other editable cells (textbox type) columns doesn't work. User is unable to enter any value in it.
The editable columns becomes uneditable when the application is used in Citrix environment
An urgent solution for the same would really help.
  • 22852
    How do the users enter edit mode?
    Do alternate ways of entering edit mode work?  Can they edit the cells if they press F2 to toggle edit mode?
    Alan
