180
Multiselectable dropdown User Control
Normal 0 false 21 false false false ES-AR X-NONE X-NONE MicrosoftInternetExplorer4
Hi
I am using  Infragistic Version 6.3
I need to make a multiselectable user control, my strategy is to combine an UltraTextEditor control with an UltraGrid control, but I have a problem. When I drag my user control to the form and them in designd tiem I asigne a value to the DataSource and after that I go to the collection property and modify some values by default, for example Hidden= true.
I execute the program, it keeps showing all the columns. The code of the grid is not added to the Designer.vb file.
This is the example code.
Public Class UserControl1
    'Private g As Infragistics.Win.UltraWinGrid.UltraGrid = New Win.UltraWinGrid.UltraGrid()
    Private g As Infragistics.Win.UltraWinGrid.UltraDropDown = New Win.UltraWinGrid.UltraDropDown
    <RefreshProperties(RefreshProperties.All)> _
 Public ReadOnly Property Collection() As Infragistics.Win.UltraWinGrid.ColumnsCollection
        Get
            Return Me.g.DisplayLayout.Bands(0).Columns()
        End Get
    End Property
    <DefaultValue(CStr(Nothing)), AttributeProvider(GetType(IListSource)), RefreshProperties(RefreshProperties.All)> _
  Public Property DataSource() As Object
        Get
            Return Me.g.DataSource
        End Get
        Set(ByVal value As Object)
            Me.g.DataSource = value
        End Set
    End Property
    Sub New()
        ' This call is required by the Windows Form Designer.
        InitializeComponent()
        Me.Controls.Add(g)
        Dim b As New Infragistics.Win.UltraWinEditors.DropDownEditorButton
        b.Control = g
        g.Width = UltraTextEditor1.Width
        UltraTextEditor1.ButtonsRight.Add(b)
        ' Add any initialization after the InitializeComponent() call.
    End Sub
    Private Sub UserControl1_Resize(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Resize
    End Sub
End Class
Do you have any idea of what might be the problem?
sorry about my English....
  • 469350
    Suggested Answer
    Getting this to work will probably be extremely difficult, if it's possible at all. What you are basically trying to do here is serialize a child control within another control.
    If you exposed the WinGrid as a public property on your UserControl and also added some attributes on the property like DesignerSerializationVisibility, it might work, but I suspect the grid's serialization is too complex for it to work a a child property of another control.
    I recommend that you either handle the InitializeLayout event of the grid inside the UserControl and hide the columns there, or else you save the grid layout to a file at design-time and then load it into the grid at run-time.
